ebemis
Sorry I don’t have pictures just yet but…
I discovered today the “L” shaped brackets that provide the cable hanging point & the ridge pole on our front bed to be ….. yes this sounds weird and a picture will do wonders once I get one….. slightly “dog eared bent up” at the 4 screw point corners. The screw that goes all the way through the bed platform and has a large washer on the outside skin appears sound and secure. This presents as if the actual platform has tried to pull down away from the cable but I know I’m not THAT fat to cause such a thing, ….well at least I hope so!
- Anyone know how much aluminum frame support is sandwiched between the inner and outer skins at that L-bracket point where the screws go into and through the platform?
- Has anyone else suffered similar issues?
- Has anyone added any sort of larger face plate work or support to this mounting areas?
THANKS! ( I promise pictures when I return for closer inspection)
