If you have the front to back space, go with the 320, the elongated oval bowl is so much easier to find accessories for. They all should bolt up with the same pattern. I just installed a Toto Washlet C5 bidet on my 320, and it is luxury personified.
They make RV specific Bidets which are all non-electric as far as I could find, and they're all pretty basic... I had a cheap one that decided to start leaking on my floor last week, so I upgraded as much as I could!
Just know that you're gonna have to do some fancy plumbing for any residential bidet, and if you want fancy stuff like drying, heated seat, UV sterilization, Bowl deodorization, and water heating, your also going to need an outlet nearby... Residential Bidets take water from the feed going to the toilets water tank, which uses a 7/8 Ball Cock thread pattern, whereas our RV toilets use 1/2 Iron Pipe (MIP and FIP) thread fittings.
I had a lot of PEX coming out of the floor to work with, so I installed a 1/2" sharkbite to 1/2" MIP shutoff valve (so I don't have to run back and forth to my distribution block), a 1/2" tee, (FIP, MIP, MIP) one male leg with a 1/2 FIP to 1/2 FIP braided hose to the toilet's valve, with the other leg of the tee having a 1/2" NPT Toto adapter (Toto Bidet's use a weird proprietary water connection of course) connected to the Bidet itself. It's complicated, but minimizes strain on everything, and the Washlet bidet is worth every penny.
