hunter99-FRF
Advanced Member
- Joined
- Jun 19, 2016
- Posts
- 88
Please don't shoot the messenger. I am simply asking a question to of curiosity.
I have a 2019 Forester 3051. I have a tow dolly and use a Curt pitch with the extra hitch welded at the top. I have a bike carrier I am using with a single eBike and the hitch is rated at 80lbs. Bike on hitch weighs right at 72lbs. When bike it mounted I only use the inside mount for it closest to the rear of my RV. The bike rack has a 3000lb rated rig that screws into the top i use a set of ratchet straps with, looped around the bumper past the mounts, to add extra stability.
With the tow dolly I am within the 750lb weight limit as the whole setup is around 500lbs so not problem there. Now I would never do this with a travel trailer bumper as the 4" tube is much thinner, but the bumper and welds on the Class C are much heavier. The steel bumper is much more substantial and the mounts are a much stronger weld for the mounts that bolt to the frame.
I am curious if I would run into problems if I mount a 2" receiver to the bumper and move the bike rack there? I would still use the ratchet straps, along with a bolt on anti-rattle hitch stabilizer with the bike rack. It would also still only be the one bike. That will not change. Total weight with the hitch as weighed is 91lbs. With is stabilized so it cannot bounce, the bike mounted to the inside, would this even be possible?
I am only considering this as I currently have to remove the bike rack to unhitch the dolly. Not always convenient to do. As I mentioned I know the limitations of doing this, the bounce can cause extreme twisted loads to the bumper, and that this isn't remotely possible on any trailer. Just wondering about thoughts on a motorhome.
