ColoFatherOf3
- Joined
- Oct 11, 2023
- Posts
- 11
The Flagstaff 26SRD has these specs:
Hitch Weight
716 lb.
UVW
6,509 lb.
CCC
2,007 lb.
Exterior Length
29' 9"
Thus, a GVWR of (6509 + 2007) = 8516.
I'm buying a 2025 Ford F150 Platinum that has a payload capacity of about 1400 lbs.
A bigger truck is NOT an option for me as I can only get a 1/2 ton in my garage and I need to find a trailer to match a truck that fits in my garage, not find a truck that can pull a specific trailer.
If I assume 12.5% of GVWR on the tongue, that gives me 1064 lbs on the tongue WITHOUT A WEIGHT DISTRIBUTION HITCH.
I do plan to use a WD hitch, but even without it, I still have about 350 lbs of spare payload in my truck for passengers and other junk.
Not sure how much a WD hitch takes off the tongue.
Is this cutting it too close? Anybody out there pull one with a 1/2 ton?
thanks,
ColoFatherOf3
Hitch Weight
716 lb.
UVW
6,509 lb.
CCC
2,007 lb.
Exterior Length
29' 9"
thanks,
ColoFatherOf3
