Oct 27, 2021 #1 FI FirstFiver Senior Member Joined Nov 12, 2020 Posts 338 2019 Cardinal Limited with double vanity sinks in the bath. The fake solid surface counter which is nothing but vinyl sheet over wood is peeling up already.
Oct 28, 2021 #2 SeaDog-FRF Senior Member Joined Jan 24, 2016 Posts 12,423 Location x OK use a heat gun to warm things and reseal the covering to the sink area or see a local counter top mfg and using the existing counter top as a sample have real solid surface top made.
Oct 28, 2021 #3 OP OP FI FirstFiver Senior Member Joined Nov 12, 2020 Posts 338 I know the fix for it. Just wondering if anybody else's was coming apart.
Oct 28, 2021 #4 SeaDog-FRF Senior Member Joined Jan 24, 2016 Posts 12,423 Location x I must have missed it where you asked if anyone else had this problem I mistakenly assumed you wanted an idea on how to fix the problem. good luck
Oct 28, 2021 #5 OP OP FI FirstFiver Senior Member Joined Nov 12, 2020 Posts 338 46 years in construction, so fix is not a problem. The problem is not having enough 28hr days to get the time to do it.
