powerboatr
i have never run across this type of tile problem before.
i have a floor with 16x16 tiles
three of them are loose only on less than 1/3 of the tile area, they move enough to loosen the grout and i can flex em up about 1/8 inch but the opposite sides are firmly and soundly attached to to the concrete slab. the loose tiles do not share corners eithers with each other, and one is two over from its closest loose cousin
if i pry em up i am afraid they will pop into two pieces, has anyone ever heard of or tried injecting some sort of adhesive under a tile to rebond it to the floor?
i have thought about epoxy resin using a syringe?? like we did in composite repairs?
oh and the looses ones are differnt from the others in color if it helps
thanks
robert
thanks
robert
