sherman12
Watch this YouTube couple add solar and lithium to their old Class C project. Wild RV Life
Just start a thread here asking how and see how long before it will morph into suggestions to add solar, etcBeen so long since I turned on my converter … wonder if I’ll remember how?
First (easiest) thing is to replace the WFCO power supply board in your rig with the "Auto Detect" (Lithium Compatible) version. If you want to buy it from WFCO, it's $200, but you can get them on ebay (from the OE chinese source) for $50-$70. RV WF-8955-AD-MBA 55 Amp Converter 12VDC Main Board Assembly Replacement Unit | eBay.what would be the problem with just changing to a lithium battery without up grading the converter besides not getting the full usable power from it?
Looked at the linked listing. Looking at ALL the details the listing is for a USED unit.First (easiest) thing is to replace the WFCO power supply board in your rig with the "Auto Detect" (Lithium Compatible) version. If you want to buy it from WFCO, it's $200, but you can get them on ebay (from the OE chinese source) for $50-$70. RV WF-8955-AD-MBA 55 Amp Converter 12VDC Main Board Assembly Replacement Unit | eBay.
The 55AMP model is WF-8955-AD-MBA. Make SURE you are getting the 'AD' version!
It's an easy swap -- units fit identically. Spend a few extra $$ and get a LiFePO4 with Bluetooth monitoring. Well worth it!
Based on comments across the 'net you were one of the lucky ones.The auto detect feature needs to run through a charge cycle
It should “detect” on the second cycle
Mine worked..:. Other people were also given/sent a jumper connection to force the lithium
I had no problems when I actually swapped and used the AD converter
Just wondering why you said that? For a Berkshire 2019 39A If I have (4) lead-acid batteries that need replacing and they are roughly $180 ea = $740 I can purchase two LiFePO4's with probably same or more amp hours for the same or less money. Why would I not purchase LiFePO4's? I just need to change the settings on my charger/inverter - I am not too sure about my Battery Isolator, but I can buy a new one for $100 or so. The only real question is the coach alternator, but I think it is fine with newer batteries BMS they have now, especially on something like SOK BatteriesBefore going to lithium batteries, how much do you plan to boondock or Wally-dock to justify the expense?
With a new "battery isolator", a Li-Bim, your alternator will be just fine.Just wondering why you said that? For a Berkshire 2019 39A If I have (4) lead-acid batteries that need replacing and they are roughly $180 ea = $740 I can purchase two LiFePO4's with probably same or more amp hours for the same or less money. Why would I not purchase LiFePO4's? I just need to change the settings on my charger/inverter - I am not too sure about my Battery Isolator, but I can buy a new one for $100 or so. The only real question is the coach alternator, but I think it is fine with newer batteries BMS they have now, especially on something like SOK Batteries
While one can get by with the original converter changing to a Lithium Ready one will yield faster charging when on Shore power or generator. Also less reliance on solar to top off and balance cells.I hope I’m not hijacking this thread by asking a question but I feel like it applies to the topic at hand, so here goes:
I have a 2021 Geo Pro 20BHS with a roof mount 190w solar panel and PWM controller. For a power center I have a WFCO WF-8735P and for batteries I have two 6v golf cart batteries. I’m looking at switching to LFP batteries. As far as I understand, my converter won’t top off the LFP batteries. But, will my associated solar setup do that? I know I can switch the controller to LFP mode. Would there be any benefit to switching out the converter to one that is lithium ready?
