this is for the LCI awning with the external motor not the one in the tube . my awning just stopped working this week so after checking things out i found it was the motor .
pulled the motor off and took it apart to find out it was very corroded and one of the wires to the brush were broke form the corrosion so i re soldered it and it fixed it for now .
so i got to looking into a replacement one just to have on hand , i did find the factory replacement one from a price of 160 to 200 on e-bay but after some research on this form i found out it was just a power window motor with a modified motor shaft for the over ride nut on the top to run the awning out with a 7/16 socket and drill if it failed . so i searched power window motors and found a dorman part # 742-102 that is an exact fit as for bolt pattern and gear minus the external over ride nut but it is only around $40.00 . it has the same 12 tooth gear and bolt pattern and it worked perfect
i will keep the factory one for backup .
had to make two small female spade connectors because i did not have the plug that fit the new motor but that was easy and for 40 bucks a 1/4 of the cost of the factory one it was worth it . just thought i would share this for anyone that does not want to spend 200 for a factory replacement .
