Chevy 2500 diesel, Salem 178bhsk WDH with sway question.
Bert Handsome
Mar 11, 2025
2
California
I already had the Fast Way E2 WDH from my previous pickup a 2017 1500. So I figured I could reuse it. I definitely needed the 2-1/2 ball. I got the drop set properly but setting the L brackets for the WDH are at thr lowest setting.
My front end lifted maybe 1/4-1/2" with thr brackets un place it cut that in half as it says per the setup manual but with thr brackets set low is this proper or sMy front end lifted maybe 1/4-1/2" with thr brackets un place it cut that in half as it says per the setup manual but with thr brackets set low is this proper or sMy front end lifted maybe 1/4-1/2" with thr brackets un place it cut that in half as it says per the setup manual but with thr brackets set low is this proper or should I adjust it by removing some of the washers, it is currently at 4
Not sure why it did this weird line duplication, and I can't edit the post. So let me declutter and fix some fat thumb typos..
My front end lifted maybe 1/4-1/2" without the WDH and with the WDH it cut that in half as it says per the setup manual but with the brackets set low is this proper or should I adjust it by removing some of the washers, it is currently at 4
Or just forget the WDH part, as I stated I already have it so it doesn't cost me anything and where I am it is windy often so I was thinking mostly for the sway control.
