Gidyupgo
Chief tinkerer
OK, so this may not be revolutionary, but it sure works for me. No scaffolding required. Work from the third or fourth step of your ladder from the front.
Harbor freight random orbital, 2" PVC and a Christmas tree on/off switch.
Heat the PVC and push the buffer handle inside. The PVC holds the buffer switch on. Run the cord inside the pipe, plug it into the Christmas tree switch that you use to turn it on once it's resting against the surface. Put your Mcguires, etc on the buffer pad and smear it on the surface. Simple
