coachmen pursuit tv problem
Becky Morris
Oct 18, 2019
5
How do I remove a wall mount tv from the rv (living room and outside tvs) I want to attach a HDMI cable to both of them. I have tried everything and cannot get them out. I don't see any straps or latches, etc, holding them in.
T> Thanks,
Becky
If they are like (and probably are) leveraged prying is the key. It’s probably a slotted fit bracket.
It lifts up and then out at least for the living room TV. I have removed it to attach a HDMI cable and plug it into a inverter. I think the outside one is more permanently mounted.
2016 Pursuit 29sb
Pursuit TV mounts
Attached is photos of the mount and back of TV when removed from kitchen area. It took a lot of effort the first time to remove it.
Same as above. Check the screws for tightness I had one screw fall out and found the other three were loose on our return of this last trip.
After much coaxing, I was finally able to get the living room TV out. Mine was just like the picture you posted. Thanks for your help. I'm still working on the outside TV. More complicated!
