I have a 2015 Blue Ridge 3025 RL that I am trying to setup a DISH VIP922 receiver with a Winegard Carryout G3 satellite. The system requires two coax cables. I can set the system up by attaching the cables directly to the receiver and everything works as it should. When I try to attach the cables through the connections that are on the 5th wheel, it does not work. I don't have a manual explaining what all of the connections are. I've tried all combinations and none seem to work. Connections 1, 2, and 3 are in the exterior panel where the water fill and external shower is. Connection 3 says " Park Cable". Connections 4 and 5 are inside just above the TV. # 6 is in the storage compartment with an exposed coax cable. I don't know where this cable goes.
Any help on setting this up would be greatly appreciated. Thanks....
