2020 Palomino Solaire 240BHS
I am having an issue with plugging Shore power into the trailer. I am popping the breaker on the home, not at all in the trailer. I have a dedicated 30amp plug in for our camper that is less than a year old.
After troubleshooting, I am finding that it trips the home breaker every time I switch the converter breaker on in the trailer. It will trip every time regardless if all trailer breakers are on or ONLY the converter breaker.
Things I have tried:
Checked to make sure 30amp is wired to 120v, not 240v
I've checked my shore power cable, it is ok
I have disconnected the converter power source from the it's trailer breaker to test the breaker, it's worked fine and help power
I put power back to the converter and disconnected the red/white feed cables taking it to the 12v side of the circuit board. Converter powers on and does not trip breaker.
I have removed every 15amp fuse on the 12v side, put power to the converter and one by one, placed the fuses back into necessary spots, this will not trip the house breaker and works fine.
Can converters go bad and loose there "oompf" when powering up? I feel like it is a load issue but of a specific circuit was the issue shouldn't it of popped the breaker when I placed the fuses 1 by 1?
Thanks!!
Thanks!!
