1973Bronco
I am upgrading my 12-volt power from the original battery to 2 Lithium batteries. I'm going to relocate the batteries and solar controller to the pass-through storage area in the front of the trailer. This will require creating a hole for the battery cables and the incoming solar wires. I've looked at a lot of info on working with the coroplast to get an idea of how to do it, but I would like any suggestions that may be helpful to my plan.
Many sources mention that the coroplast is attached with screws or rivet-type fasteners. I haven't seen any type of fasteners on my Puma in the area that I'm looking at, so I suppose I'll have to cut that material. I've seen the cuts as either two sides cut to create a triangle opening or a three sides cuts to to make a rectangular flap. Any thoughts on one being better then the other?
Since I will be putting wires through that opening it will not seal up completely when the flap is closed, so should I use some type of foam to seal around the wires, or just do a heavy tape job with something like Gorilla Tape? This incoming solar wire is from the "Solar on the Side" but I plan on adding solar panels on the roof next year, so I will need to reaccess this opening then for wiring to go through.
Any comments or suggestions would be greatly appreciated.
