Spower001
I am headed to Pennsylvania cold in a few days. I am worried about keep my enclosed underbelly warm!
I did a test last night where I am currently at.
I put a temp sensor inside the underbelly about 1/3 of the way from front of trailer where tanks are located.
I did not run heat all night.
The temp in underbelly was the same as the outside temp (36*)! I was told it was insulated but it is not!
This morning i started the furnace....inside RV warms up fast, the underbelly went up one degree! Or maybe not, it is matching what the outside temp is.
Question.....can I try to find an area inside the underbelly and put a space heater with a thermostat in there?
When I get to PA I do plan to put up foam board enclosing the trailer bottom but that most likely won't be enough against 20 degree weather.
Ideas?
Ideas?
