red_georgia
Advanced Member
- Joined
- Jul 17, 2020
- Posts
- 42
Added two thermostat controlled fans to top of vent stack this weekend. During that process, discovered a very poorly designed vent attachment method. The screws are oriented vertically and create four vertical paths for water to collect on top of the screws. The screws used (provided by Dometic I assume) "were" black oxide. The screws were completely rusted (and the vertical column stained with rusty water that sits in the hole) and almost disintegrated when I removed them to access top of vent stack. This is a 2021 unit....screws almost unusable. I replaced them with stainless..... quick fix for those of you with same fridge/vent arrangement. A few more years and I'm guessing those screws would never come out. Small job to avoid bigger one in future (replace vent assembly).
