Use Lexel on the gasket where the top and bottom pieces connect. I had posted pics earlier in thread.
I found your post and will do what you did. Thanks.
Is it built differently? I thought not?I got a replacement Dometic toilet for my 2019 Rockwood. The smell was horrific. Dometic sent the new model 300. I replaced the toilet myself. I lifted the toilet after turning off the water and cleaning the bowl. When I lifted it straight up ugly brown water spilled from the back. I disinfected the floor and got the toilet into the box of the new toilet. The new toilet went in easily but I am hoping since it’s the new model 300 made in March of 2022 that we will not have the smell.
I thank Fometic for the replacement and hope I don’t need another. After 4 days no smell.
I read that it’s been improved to stop the problem on an RV site. I forget the site where I read it though.
I was treated fairly by Dometic when I encountered the odor issue. Dometic sent me a new model 3O0 when it was available in April of 2022. My Rockwood was a 2019 I purchased new. I installed the new model 300 but after 5 days the smell was back. I contacted Dometic and they sent me a model 310 which fit perfectly and is part ceramic part plastic. It works well and no smell.
I don’t know of a repair kit but I did see a YouTube video where someone took the toilet apart and resealed the inside.
If you bought a used trailer Dometic may not send out a new one since it is not a recall item. I would suggest buying the 310 model on Amazon and it should fit your model trailer. You need 10 inches on each side from the wall for the bolts to fit in. If the 300 fit the 310 model should fit fine. I’ve heard the model 320 is larger and will not fit in my Rockwood ultra lite.
You can't hide the smell of an open sewer.... We tried a variety of ways to cover the smell but the 310 took care of it.
I thank Dometic for the replacement and hope I don’t need another. After 4 days no smell.
You've been a member for 8 years and this is your first post? And why are you having problems navigating the Forum? After 8 years, you shouldn't be having problems.Sorry I can't help! I am just trying to Navigate this site.
