Sunseeker16
- Joined
- Jun 30, 2020
- Messages
- 1,562
I have a leaking black tank valve. Does anyone know if the 3 inch and 1 1/2 inch dump valves are a standard bolt pattern. If I'm changing one I might as well do both.
I get that. I don't think that will be an issue for me. There is a rubber fitting on one end. My concern is do all the manufacturers of the valves use the same bolt spacing?
Sorry for any confusion. The rubber fitting is like a rubber Fernco fitting held on with a clamp. I assume it's clamped to the tank outlet.
