E450 A/C Cuts Out on Mountain Climbs—Vacuum Issue or Normal?
msrdo
RV LIFE Pro
Mar 17, 2025
25
Grenada,MS
We are still learning this magical mystery machine. Have travelled with the group's input from MS to lower Cal and now up to Wy near Yellowstone. Been a great ride! I have a question though as to the expected performance of the engine systems in the mountains. I have noticed that at altitude... say above 4-5000 feet, when I accelerate to climb and the transmission downshifts, I lose A/C. It seems the A/C valves cause diversion of the airflow to the windshield. I assume the increase in altitude affects the capability for vacuum and thus causes the A/C diversion valves to change. A/C promptly returns when the hill is topped and the transmission downshifts. It has been consistent, so I assume expected, or is there a vacuum issue? Sorry for the newbie questions, but thanks in advance!
Moved thread from the General Tech and Repair section to the Motorhome section's Forester and Sunseeker sub-forum for better help from other Forester owners and possible factory support.
Also because the issues are related to the motorhome chassis.
As you suspect this is a chassis issue -- Ford -- not a Forest River issue. Local Ford truck shop probably has a cure although those in Mississippi will have little experience with high altitude issues so check out there in Montana before you go home. Cursory web search turned up:
The AC system on your ... E 450 is designed to divert to defrost when the system loses vacuum and this a pretty common problem on your E450. The common cause for this is in most cases due to a leaking vacuum storage reservoir that is located inside the evaporator case and in most cases, replacing it will resolve this problem for you.
-- Chuck
Several more suggestions are listed in "Similar threads" below. Not sure if they were there before. The forum seems to have a very helpful algorithm that links these.
