Electrical wiring- control panel
ClintWells
Mar 20, 2025
4
Michigan
I have a 2023 Vibe 28BHE. The slide switch was loose, so I removed the panel to see what could be done. While doing so, the blue/white wire (which i think is a jumper from the water heater switch) came disconnected from the water pump switch.
Also, the brown and green/white came disconnected. I don't know which wire goes to which switch.
Anyone know where they should land? Green/white to pump? Or water heater?
Oh man, I just had mine pulled apart 2 weeks ago and I have a very similar pictures, but not the same rig. Let me see if my pic has enough info...
Now that I have found the pic, it probably doesn't have enough. It also looks like the wires aren't even nearly the same colors for the switches you mention. That said, if there is anything I can do, I'll happily open it up again later tonight or this weekend.
P.S. I also had some wires that had come loose in here. My troubleshooting brought me inside this panel when my porch LED lights stopped working suddenly one night. I opened up this panel, and boom, the wire had come completely loose from its crimp (but was luckily still positioned closely enough from "wire memory" to track down where it belonged).
I recall finding one more loose wire while playing in there, but it was less memorable because I found it before the item quit working....
It's probably not the best way, but I did a bit of assuming.
Connected what I thought where the blue/white jumper went...that made the switch light up red when turned on. So that worked.
Then I tried one the last two wires. Connected and turned on. If I heard the water pump kick on, I knew it was that one.
Then I removed that wire and tried the other wire, no pump on but heard the water heater click.
So, I tightened the grips on the clip and put back together.
While I had it open, I made a diagram for myself that I'll leave in my camper. Did some labeling on the connectors to help I identify against my diagram. Hope this is helpful
