Greywuff
Advanced Member
- Joined
- May 17, 2021
- Posts
- 56
Aggravated with fridge going into safety and not cooling for 6- day trip. Repeatedly reset fridge and ended up defrosting coil with wife's hairdryer. Worked for about a day and refroze. When I got home today, I removed the inner plate inside the freezer and tried to unplug a connector with a black wire going to either side of the coil. After considerable effort I finally got the plug disconnected to discover that one side of it had melted and burned off most of the clips that clip the wires together. I could not get the plug out of the freezer, nor could I access it because it is sealed between the rear sheet metal and the plastic inside the freezer. So I called Leppert for tech support.
Spoke with several people before getting to the correct department, and when I did I was informed that the plug is not replaceable, not able to be bypassed, and the unit is out of warranty. My only option is to replace the entire refrigerator.
I decided that I had nothing to lose at this point, so I proceeded to break the plug apart and remove the two wires from it. I ended up having to cut some to the plastic inner freezer wall to gain access to what was left of the plug. Upon doing so, I was able to expose enough of the wire to get clean, unburned wire.
With the help of a soldering iron, solder, shrink wrap, electrical tape, and caulking, I was able to solder the wires together and bypass the unavailable, unrepairable, unbypassable plug, and replace the freezer fan panel back into the unit.
So far, it has been operating perfectly for 8 hours. I don't know if this is a permanent solution or if I will eventually have to replace the unit, but if I do, it will not be with another Everchill product.
