Colorado-A-Frame
Advanced Member
- Joined
- Jun 26, 2016
- Posts
- 82
I recently purchased a 2018 T12RBTHSE. The unit came with many options I haven’t seen in the used market. It came with factory installed solar, in addition to the WiFi Ranger.
The roof mounted panel is no longer functional and the Go Power Solar Controller is not Lithium Battery Compatible. In addition there is a factory installed SAE connection direct to the battery.
The most important part is that the unit is pre-wired with 10 gauge wire to the roof mounted panel and to the controller…in addition there is factory installed 10 gauge wire from the controller to the battery. The system also includes a Go Power inverter…It seems functional but I haven’t tested it yet.
I set out on the project knowing that I would need to replace the roof mounted panel, upgrade the controller and would like to upgrade from an older AGM battery to Lithium.
I should preface this by also saying this isn’t our first A Frame or my first solar setup. We had a 2012 T12DDST. I added solar and converted that unit to 2 6v Deep Cycle golf cart batteries. We had a great experience with that camper before we sold it and moved overseas.
I spent a good bit of time researching and reading posts in many RV forums to find what I think is an affordable and efficient DIY solution. Of course this isn’t a one size fits all thing at all…your needs and experience may vary.
Over the past few years the advancements in solar technology is incredible. Efficiencies have increased and costs have decreased considerably. Combined with expansion in the lithium battery industry thanks to the EV world…and we have a perfect marriage for the camper community. Many new campers are delivered today with 12v systems for everything including the fridge because these systems are so much more robust than in the past.
When creating a parts list I found that the camper van world loves Victron. Their products are affordable, robust and there is a ton of online support for newbies such as myself.
I decided that the Victron 100/30 Solar controller would work great for our application. We will have one permanently mounted roof panel to replace the factory panel and I also decided to add a portable panel to the system as well. I also decided to monitor the system with the Victron BMV-712 Smart Shunt and the MPPT Panel mount controller. While the solar controller is blue tooth capable I like the idea of being able to see the status at a glance.
All of this power needs to be stored…but where. I went down a deep hole into the Lithium Battery world. There is a guy on YouTube who’s awesome. @WillProwse has a series of videos where he dissects batteries, controllers and DIY solar gear. He’s interesting and creates incredible content. I initially had planned to go with a single 100ah battle born battery…at the cost of less than $500 it seemed like a good solution until I found @WillProwse his review to of the LiTime batteries stopped me in my tracks. There is a lot to discuss with regards to Lithium batteries but to summarize they either need to be relocated to the conditioned interior of the camper or self-heating (if you plan to camper in colder climates.) I planned to keep the batteries located out on the tongue for ease/cost and safety reasons. After watching a few reviews I went with 2 LiTime self-heated, 100ah batteries at less than $500!
I’ve been chipping away at the project. So far I have the controller and shunt installed, and panel replaced. I’ve upgraded the batteries with a new box and have cleaned up a bunch of wiring. It’s a work in progress but here are a few pictures of what I’ve done so far…and some before and after.
I’m always open to advice, opinions and suggestions. I thought I’d share my journey in hopes it might help other who are either contemplating the same project or have experience with their own.
