- Joined
- Nov 27, 2021
- Messages
- 7
RV: 2019 Arctic Wolf 298QSL8 5th Wheel
Problem Slide: Dinette (passenger side)
So we were sitting around our dinette and there was a sort of bang! and the floor dropped. You could see it moved down about an inch from the inside. I'm a big guy, and we're full-timing, so it sees probably more wear than it was designed for.
The slide actually goes in and out fine, and the floor pops back up into place when it comes in. We're sick of not using the dinette on that side, so yesterday we looked a lot more closely.
We initially thought the particle board subfloor dropped, when I looked at all the screw heads that had retreated deep below the surface of the bottom of the floor. So I replaced a few of them and put in a broad washer on it to expand the holding area, and added more screws. Didn't fix it.
So we took the fascia off and saw that what looks to be a metal support beam that is dipping in the middle with the whole floor. In the attached pictures you can see the end, where it should be, and the middle, where it's dipping.
There isn't much there to attach to that we can see, though it's only down an inch or so.
There doesn't appear to be any rot, though we got some water in there during the tail end of a hurricane in FL, this happened before that. And there's no sign of rot.
The area was repaired after a blowout (by Camping World, who was the only dealer within 100 miles who could get the parts from Forest River) and we saw some sub-excellent work on the repairs. e.g. the flashing seal job wasn't excellent.
From reading other threads on here, what I suspect happened is that this floor section is held up by barely adequate screws through the base frame on the slide wall, and two+ years of my portly backsides sitting on that spot ripped them out.
I think I may be able to fix this without replacing the floor and destroying the wall by:
1) Jacking up the floor until it's back where it's supposed to be.
2) Running longer screws from the underneath back up into the bottom frame of the slide wall.
I'm looking for thoughts, and information on this. Specifically:
1) Has anyone else fixed something like this on a FR slideout, and will my approach work?
2) Does anyone have a good picture or idea of what the slide wall bottom looks like so I know what I'm screwing into?
3) Any clue how long the screws need to be to get the holding I need?
Thanks in advance. Here are a couple more pictures:
