If you have the waterfall style, you may want to replace it with one that doesn’t spit water all over you each time you hookup to a new site. See this thread for a faucet suggestion and for the needed adapters. I swapped out both of ours and have been much happier (and drier…).
Best views in the park are at Hurricane Ridge but that entrance is by Port Angeles. From BC you might consider a ferry ride to Port Townsend and cut the Olympia loop out.
SORRY: this reply was intended for a different thread.
I had a cartridge go bad in the kitchen faucet and wanted to get rid of the waterfall faucet in the bathroom so I swapped the cartridge from bath to kitchen faucet and replaced the bathroom faucet.
I used a Moen 'Hensley' faucet, Moen P/N WS84414MSRN as it fits the available hole and readiy hooks to the RV plumbing using a 3/6 compression to 1/2 NPTF brass adaptor. You do not use the compression fittings (furrel and nut); the face and threads of the fitting make an o-ring face seal. Works a treat!
