Flagstaff 2008 5th wheel classic lite battery issues
barg79
Jan 3, 2025
2
Georgia
My battery keeps dying on cold nights then recharging during the day when it's warmer. Also all my plugs run on battery not my shore power. I have check fuse and bought a new battery. And yet to find a solution. Any advice should be helpful.
Make and model of the RV and more details about useage would be helpful.
We need way more information.
120v plugs do not run off battery unless you have an INverter. Do you?
Do you have solar?
Are you plugged into shore power?
What is your shore power. 30a or 50a?
Are you using any kind of adapter if plugged into shore power?
Do you have solar?
These are the original plugs and if the battery dead they don't work.GFCI class a 20a/125v/60hz/15a ....I do have in inverter that shows the battery charging, voltage etc....no solar power and have my fuse/electric power panel is parallax 7100 Series 55amp...I am connected to shore power and I'm not using any kind of attachments to plug in but the power cord 30 am
Inverter off!
How many batteries?
Battery size?
Battery voltage when charged. 24 hr charge. Using a voltmeter 1 hour after charging.
Battery voltage with shore power on. Do outlets work.
Inverter off for now.
After we have the numbers help is on the way.
