RVrover
[FONT=Candara, sans-serif]Hello everyone,[/FONT]
[FONT=Candara, sans-serif]Thanks to "Harvard", a well known OP on the topic here and elsewhere,[/FONT][FONT=Candara, sans-serif] I compiled this posting for the benefit of everyone new to it. It will vastly reduce, if not solve, most of the handling issues that plague most Ford E350/E450 with a very simple solution that will improve your driving experience and save you a lot of money and aggravation.[/FONT]
[FONT=Candara, sans-serif]Background:[/FONT]
[FONT=Candara, sans-serif]I own a 32 ft. class C Forrest River SunSeeker 2018 built on a 2017 Ford E-450. After only 25K miles on it (bought it new), I wore out my front wheels that came with the RV (Hankook Dynapro HT LT225/75R16 115/112S). I thought this is low mileage for such damage (see the driver's side attached, which was worse than the passenger side. Both sides had worn more from the inside than the outside).
I replaced the 2 front tires with Cooper tires. I followed up by doing the alignment at the same shop. Unfortunately, once I left the shop, the RV started to pull left, dramatically and unlike any time I had it for the past three years. When I went back to the shop, they drove it and did the alignment again. The same thing happened immediately, so they did it one more time.[/FONT]
[FONT=Candara, sans-serif]Nothing worked and this is where I decided to dig up the issue online. Here is what I learned, thanks again to Harvard and others in various forums.[/FONT]
[FONT=Candara, sans-serif]1. When you buy your RV, check the alignment. Don't let dealers or FR dismiss your concern about the bad handling or wandering as "normal". You can do better. I've never been told by either parties about this despite me complaining from day one, which is disappointing! [/FONT]
[FONT=Candara, sans-serif]Ford ships all E350/E450 cutaways with standard alignment. Manufacturers like FR extend its chassis and build the RV on top of it, but don't do any realignment for their own reasons. I've been told that FR will compensate you for alignment up to $300 as long as it is within 90 days from buying your RV. [/FONT]
[FONT=Candara, sans-serif]2. You can improve the handling and steering by adding many after market components than the standard parts that Ford or FR sell you, which many say (and I agree) that both FORD & FR should vastly improve these inferior parts before selling these RVs. Many posts are available on forums about this. Check them if you are interested. Examples are: [/FONT]
Ford ships all E350/E450 cutaways with identical fixed, nonadjustable caster/camber sleeves, "one size fits all". You can recognize these sleeves because they are keyed and can't be rotated. The RV builder almost never changes the Ford sleeves, as a result:[/FONT]
[FONT=Candara, sans-serif]Install these new sleeves: The torque on the Pinch Bolt is around 65-ft-lb. they should be installed Clean and Dry, not oiled or greased. Then SET TO 0.0 Degrees CAMBER and +2.0 Degrees CASTER then align the TOE IN to be within TOE spec while accepting the resulting CAMBER and CASTER AS IS.[/FONT][FONT=Candara, sans-serif] Go for the most + CASTER you could get and accepted the CAMBER to be as close as you could get it without sacrificing any available +CASTER. [/FONT][FONT=Candara, sans-serif]See my after results attached.[/FONT]
The Ford Spec for front end CASTER is:
LH +1.3 to +6.8 Degrees
RH +1.8 to +7.3 Degrees
Harvard's unit was:
LH +3.3 Degrees
RH +3.5 Degrees
Add + 2.0 degrees, so we are now at:
LH (driver side) +5.3 Degrees
RH (passenger side) +5.5 Degrees.*[/FONT]
[FONT=Candara, sans-serif]*Notice that passenger side gets more + caster because we normally drive on the Right Hand side of a road crown.
Harvard's theory is all E350/E450 probably handle badly below about +4.0 degrees which is still inside Ford spec. Lets say there is a grey area between +3.5 to +5.0 where load distribution would add to the confusion. Below +3.5 is no mans land no matter what the weight distribution.
PS. if you find that your RV CASTER is ALREADY above +5.0 then DO NOT ORDER ANY PARTS, they will not help you beyond where you are now sitting.
[/FONT][FONT=Candara, sans-serif]Last: [/FONT][FONT=Candara, sans-serif]Why take the chance of having abnormal tire wear by not having the CAMBER SPOT ON? Harvard said [/FONT][FONT=Candara, sans-serif]that in five years he has driven over 30,000 miles and have no problem what so ever with any abnormal tire wear.[/FONT]
[FONT=Candara, sans-serif] I hope Harvard and others will correct anything here that is out of date or incorrect. I am completely new to this, but it was worth the effort, money, and time spent researching it and doing it.[/FONT]
[FONT=Candara, sans-serif]If you're in or around Las Cruces, Southern New Mexico, the shop who done the job is: Mesilla Valley Commercial Tire. Ask for Nick (manager) & Ben (Technician). If you are not in the area, this post has all you need to ask any shop to do it for you. Best of luck! - Sam[/FONT]
- [FONT=Candara, sans-serif]Front and Rear HD sway bars[/FONT]
- [FONT=Candara, sans-serif]Rear Trac bar[/FONT]
- [FONT=Candara, sans-serif]New adjustable steering stabilizer[/FONT]
- [FONT=Candara, sans-serif]If the final RV build is nose down one degree then the runtime caster will be about +3.5 degrees. These units can have a real wandering problem.[/FONT]
- [FONT=Candara, sans-serif]If the final RV build is nose level then the runtime caster will be about +4.5 degrees. These units are probably indifferent.[/FONT]
- [FONT=Candara, sans-serif]If the final RV build is nose up one degree then the runtime caster will be about +5.5 degrees. These units are probably just fine.[/FONT]
- [FONT=Candara, sans-serif]Your RV feels like the steering box needs to be tightened up having seemingly excessive play because of the need to continually going back and forth through the neutral zone.[/FONT]
- [FONT=Candara, sans-serif]Feeling the negative effects of bump steering.[/FONT]
- [FONT=Candara, sans-serif]Cross winds, trucks passing, and wind gusts cause havoc on you.[/FONT]
- [FONT=Candara, sans-serif]Feeling not having enough weight on the front axle.[/FONT]
- [FONT=Candara, sans-serif]The effect of sway causing a change in camber which in turn results in a change in toe.[/FONT]
- [FONT=Candara, sans-serif]Your tail is wagging the dog.[/FONT]
- [FONT=Candara, sans-serif]You need to drive it all day and never relax doing so.[/FONT]
- [FONT=Candara, sans-serif]NCP 2641988 by INGALLS sleeve (LINK)[/FONT]
- [FONT=Candara, sans-serif]SPC794 (SPC PN 24180) equivalent to the Ingalls (LINK) [/FONT]
- [FONT=Candara, sans-serif]MOOG Caster/Camber Adjusting Bushing (LINK)[/FONT]
- [FONT=Candara, sans-serif]Specialty product company part 23187 or 23188 (LINK)[/FONT]
Harvard's unit was:
LH +3.3 Degrees
RH +3.5 Degrees
