Hello all, sonas the title states, water is just lukewarm. We believe it started end of season last year, or at least that's when we noticed somthing wasn't right. We just attributed it too cold incoming water, and cold outside temps.
But Sometimes you get a burst of hot water then lukewarm. So far I've checked the tank itself. The top of the tank measuring 130-135. The thermostats are good. Does it both eletric and propane. I have no outside shower with hotwater just a small hose thats cold only
I've double and triple checked the winterizing valves. I have a 2 valve setup they are both pointing toward the tank. Even went as far as to crimp the crossover line with no change. Pulled anode rod and there is little to no sediment and I can clearly see the cold water dip tube.
I think it's mixing somewhere but I'm running out of places to check. Any ideas? Is there a weird valce somewhere I'm not seeing?
