FishingGirl
- Joined
- Mar 26, 2022
- Posts
- 3
I bought an Isata 5 in September of 2022 new. On the drive home it caught on fire. It was towed to a dealer and someone from Forest River made the repairs. We got NO documentation of the repair but were told that a zip tie holding a hydraulic line broke and it ignited on the exhaust pipe.
Once it was repaired we drove it home and have not used it since. When we tried to prep for a trip we found that the slides wouldn’t open fully and there was a problem with the electric mother board.
It has been in the shop since October of 2024. The repair team said the board had to be replaced, along with all 4 slide motors. There was water intrusion that caused corrosion. The intrusion was at the factory corners. After replacing all 4 motors they noted that one slide wouldn’t open straight. Upon further inspection they noted that one of the tracks had been previously removed and new screw holes made during reinstall. This caused the slide to close and open crooked. The repair center won’t warranty their work because someone else didn’t fix it correctly and we cannot use the slide.
I contacted FR for help on February 19th. They have no record of a fire. They show no one has done work on the unit other than fixing the hydraulic line. My issue was forwarded to Dealer services on February 26th. Since then I have left phone and email messages and have gotten no response.
We basically own a new RV that we cannot use and no one from Forest River seems to want to help. Not sure what to do at this point.
