see attachment
Last fall I posted that I almost failed inspection because my rear marker lights were working but not well. I passed the inspection and went shopping over the next few months (I was parked in a Florida CG for 4 1/2 months). I found that the C.W. and other dealers were getting almost $30 per light fixture and the five assemblies almost $200 if I installed them.
I also learned a bit about the marker lights and Forest River on my unit used assemblies that are NOT sealed from outside moisture and also there is a possibility of installing them wrong and a tiny drain hole in the lens could be installed with the hole pointed up allowing water in. On my unit two of the five rear marker lights were installed upside down and the one in the picture was the worst and you can see the circuit board was in very bad shape. You can also see on the red lens the 1/4" long slot on the right side, that is the drain hole and opposite side the rust stain where the water pooled.
Even the ones installed with the drain hole pointed down had some dust and road grime inside the lens. The lens and the base assembly both have the word "top" embossed in the plastic but it's hard to see. I guess Murphy's Law caught up with me.
I finally found a replacement assembly that is hermetically sealed and has an almost identical footprint. I installed them in about an hour and also went a bit overboard by caulking the back side around the wires and around the outside to keep any possible moisture out. I had to drill new holes for the mounting screws, and I used stainless screws.
I don't have the name of the company that made them, but I found them on Amazon and sold by RecPro.com.
