Hi all. I have a 2021 Apex Tera, it's a small 15' camper but it's set up for boondocking and has a 50 gal fresh water tank.
However, we can never get the last 7-10 gallons of water in the tank because the outflow valve (not sure what it's called) is mounted on the side.
In the image you can see where the blue hose that I referred to as the "outflow valve" is coming out the side instead of the bottom. It doesn't have a hose clamp because I cut it off so I could unscrew it and look inside because my suspicion was that there was a straw attached that allows it to get the water in the bottom of the tank. But I couldn't see anything but the reflection on the surface of the water sitting in the tank. (That water can never be drained out, even the dump valve isn't low enough).
Should I have the dealer re-mount the valve underneath the tank? I'm not sure how to fix this problem, it always leaves us with a lot of water we can't use. Also, the tank is permanently enclosed in the frame of the trailer, so I don't believe I can swap it out. Suggestions are welcome, thanks.
