salemcruise
- Joined
- May 7, 2024
- Posts
- 16
Hi all, feel like I'm posting here a lot lately but can't argue that the community support and information is really helpful!
Anyway, I was just prepping our 2018 201BHXL for the weekend and wanted to just flush the lines from the fresh water tank with a quick spray before we go to ensure everything was working with the pump and lines. Lo and behold, found an issue.
Almost immediately while adding water in to the tank through the side hose intake, I noticed it was basically pouring straight out on to the ground with nothing going into the tank. To confirm, I opened the drain spout on the fresh water tank and no water came out, it was dry as a bone.
From how it was leaking, it appeared to me as though the water was going through the hose itself, and then just dumping on to the top of the tank then leaking down the sides to the ground. From what I can tell, it seems like maybe the hose connecting to the tank became dislodged while I was towing it last. My best guess is the hose clamp just loosened up too much and the hose came off going over a pothole or something.
Anyway, I can't for the life of me figure out how to get to the top of the tank to inspect the hose connection. It looks like the hose runs through the inside of the trailer under the sink from the outside, then back through the floor to the exterior mounted water basin. I've attached 3 pictures to show what I mean, 1 where the hose comes in to the trailer, 2 where it exits through the floor to the tank, and 3 the tank itself mounted under the trailer on the frame. I had my wife put water through the hose while I was looking at it from the inside and I can confirm the water goes through the hose and out through the floor opening without leaking anywhere in the trailer itself. Inspecting the basin itself I don't see any cracks, and the "leak" definitely looks like water running over the top of the basin, down the sides, then to the bottom where it drips off.
My question is: does anyone know how I can get to the actual top of the tank to inspect the hose connection? I went under the trailer with a creeper and the tank just sits freely on top of two crossbars that are part of the frame. I definitely appreciate this design as my old trailer had the tank inside the trailer under one of the benches, and when it burst one year.... well, we ended up replacing half the floor. So I like this exterior mount design. But I can't figure out how to actually get to the top of the tank? Do I need to push it up and tilt it to slide it out from underneath? Or do I cut through the foam in the second picture to see where it goes under through the floor of the trailer and try to reconnect it there?
Any and all tips are appreciated. Thank you everyone as always!
