The concentration used for sanitization of "stuff" is much higher than the concentration in chlorinated drinking water.
You also have to look at the bleach you are using. Some off brands are as low as 2% sodium hypochlorite, normal bleach used to be 5-6%, and now most good brands are up to 8.5-9%. Going off "x cups of bleach per x gallons of water" does not always apply correctly, and if the bleach bottle isn't read carefully so that you know the concentration, you might end up with a tank that's not properly sanitized from using 2% at a concentration of 2 ounces in 15 gallons.
Typical 5% bleach should be used at 1/3 cup per 5 gallons for sanitization. That's a long way off from 2 ounces per 15 gallons of water. Again, I'm not saying you or FR is wrong, I'm going off of my training in chemistry and from my many years in the food service industry - the health department cares a lot about what you have in your 3 vessel sink and in your spray bottles when they come in for surprise inspections.
To sanitize drinking water, it's 1 teaspoon per 5 gallons, and you let that sit for 60 minutes. And in this "sit time", the chlorine goes away pretty quickly, in fact a lot of city water facilities are switching away from chlorination because it is effective for such a short time and going with chloramination (combination of chlorine and ammonia, please don't mix these at home either!). You might be surprised to find with some proper testing (not simple pool water strips) you have zero or near zero chlorine in your tap water, but regardless it's going to be too low to cause you to die from chlorine gas in your house. If you've ever had pet fish in a fish tank, you know to either let your fresh water sit for a day before adding fish, or you have the drops to remove the chlorine, but either way it does not stick around.
My post was simply to ensure people are careful. I was not picking on you.
