Fresh water tank vent/overfill
JoeDakar
Advanced Member
Aug 9, 2020
30
Antelope Valley, CA
As most of us have discovered, the factory manuals are so generic, nothing applicable to your specific model can be found there to learn the details of any specific FR RV. So I’m asking these questions: where is the Fresh water tank vent plumbing line? Does it go to a roof vent? Is there a Fresh water tank overfill / overboard pipe? If so where does it dump out? Or do you just shut Off the filling Source before the “FULL” LED lights up to prevent bursting the tank/plumbing?
My previous RVs had an overfill vent next to the fill port & if your standing next to it, you get doused when it’s full!
On most rigs the vent is the overflow also I have never encountered one piped to a plumbing stack. What I have seen is vented alongside the fill pipe or to the ground. With that said I found on my rig when it came from the factory the vent/overfill was kinked at the tank connection and not working I had to pull the coroplast to find it.
I don't thing fresh water tanks have a roof vent. Our 3950 Luxury has an overflow tube that tells me when it's full. That's what I use to know when to stop the fill.
Tank vent
What is the location of the vent line drain in your Luxury? I have looked all areas under the rig, near the water hookup box and all along the underside of the trailer.
Good question! I have a 2020 Rockwood 2902SW travel trailer. When I fill the water tank full, I soon observe a water leak emitting on the underside of the trailer from the area of the tank. The water is seeping through a patch seam in the underside. I do NOT observe any over flow line exiting below the trailer membrane. When I dump a small amount of water from the tank, the water leak stops. Due:) to the position of the water tank, it is impossible to observe the connection areas of the over flow and fill line. I suspect the problem is the overflow line allowing water to exit the tank to the ground. ANY experiences with this style of issue will be appreciated!
My friends trailer would leak underneath when full, I unscrewed a panel, found a rats nest and the overflow tube. Look for panels with screws around the water tank.
My '19 3600 has three tubes sticking out of the bottom in the back left side.
One drain and the other two a vent and an overflow.
I figured the overflow and vent would be handled by one tube, but apparently not.
Photo above from Guru is what it looks like, except two uncapped lines together.
On rigs like ours that use city water connection to fill (ie powerfill), the vent/overflow has to be at least twice the capacity of the input line so that there is no chance of rupturing the water tank. The two tubes you see are both vent/overflow. On gravity fill, the simple vent line next to the fill is sufficient, although on my old TT I used to jam the hose in there, and if not paying attention, the tank would be overfull by quite a bit and gush out the fill line.
Yeah, my TT was similar. It was visible from underneath and I could just watch it fill up. The vent came out of the wall literally right next to the fill hole. The vent was a hole with a fine screen over it to keep debris out.
Fresh Water Tank
Fresh Water tank in my 388 is located directly below the forward storage compartment. The only two lines coming out are on the passenger side are the hot & cold drains. The tank drain is on the opposite side.
