I have a 2018 Flagstaff 25fks travel trailer. Would someone be able to tell me if the freshwater tank is mounted in front or behind the axles? Also is the supports for the tank adequate to support the tank when towing with water in the tank?
Forest river owners manual recommends minimum towing distance with the FW tank filled. In Other words, fill the FW tank a near as you can to your final destination.I have a 2018 Flagstaff 25fks travel trailer. Would someone be able to tell me if the freshwater tank is mounted in front or behind the axles? Also is the supports for the tank adequate to support the tank when towing with water in the tank?
