I got a fuel tank cap message as I was driving thru New Mexico in my 2020 Georgetown Gt5 with 20,000 miles, which propagated into a check engine light. Took it to a Ford Comercial vehicle dealer here in Southern California and after diagnosis was told the vehicle had a broken fuel tank vent valve and it was not covered under warranty as it was broken. Valve is located on top of 80 gallon tank with only about 6 inches of clearance between the top of tank and floor of unit. Valve nipple was actually broken off at hose connection. As there was no debris or markings on tank I find it hard to believe an outside source caused the break.
My question to all you is, have you had the same or similar failure?
