Gas stove
youwatec
Sep 23, 2024
13
2024 NoBo 19.3 gas stove stays lit for about a minute or two then goes out. Plenty of fuel. Any ideas?
Is this the first time you have used the stove? If so you have to wait for the air to purge out of the fuel line. Can you hear or smell any propane coming out of the burner? Later RJD
Have you checked the supply line for kinks?
We had a stove in a slide once that when extended, kinked the flex hose.
It would light but not enough LP passed through the kinked hose to keep a burner running.
Has it always been this way or is this something new happening?
2024... did it work during your Customer Orientation/PDI?
Did you recently run out of propane?
Did you turn the knob(tank) too quickly? If so, it would activate safety feature and lock up flow.
Check connection of your gas line to your tank. Ensure it is tight and secured.
If you have dual propane, make sure selector valve points to the one that is ON and has propane. Guilty of that...I selected an empty tank..duh.
