Not sure we need more info....in 99.9999999999% of posts that start with "gen runs, but no power" it is 100% of the time, the breaker on the generator is off.
However, make and model of coach is always helpful.
Edit: sorry, Larry-NC pointed out the other option. So I change that to 80% of the time it is 100% the breaker. The other 20% of the time it is 100% you need to plug it in.
Though, if this post is correctly in the Dynamax section, we have used transfer switches since I have been here....so odds are breaker.
2021 Dynaquest xl 3801
Onan 8000 generator
Breaker is on
Seems like we had this problem before and had something to do with lcd
Screen in the coach but I’m not sure
Tripped the breaker on the generator didn’t help (worth a try)
Everything works when plugged to shore plug
Going to Moab this weekend would be nice to run ac
You can try cutting battery power to everything (probably three different switches, two outside and one in?)then powering everything back up. Power up your inverter last.
