happy camper 17
- Joined
- Jan 18, 2021
- Messages
- 18
Hi folks,
I am new to this forum and would like some help with a battery charging issue. I was boondocking with my 22 Rockwood Minilite 2109S and after a few days wanted to charge up my Li time 230 amp hour lithium battery. I hooked up my Genmax 4800 generator to the 30 amp cord and the converter and fridge began to operate , then shut down. I could tell that they were working because the generator showed a slight draw on the digital display, then the display went to zero. I unplugged and plugged in the cord numerous times with the same result. But the AC and the microwave all worked fine. I also tried a second 30 amp cord to see if the cord was the problem and it was not. Hooked up the 30 amp cord via adapter to the 110 plugin on the generator with the same results. I then used a 20 amp lithium charger that I hooked up directly to the battery and 110 plug on generator to power it and the battery accepted the charge just fine. Now here is the thing that confuses me. I took my Yamaha 2000 generator and hooked up the 30 amp cord via adapter and the converter fired right up and worked just fine. The Genmax generator runs just fine and does not show anything abnormal on the display.
I tried getting a hold of Genmax customer service and that has been a total nightmare. The generator is still under warranty.
I'm totally confused. Any ideas would be greatly appreciated. Thanks in advance.
