DeadSalmon
Advanced Member
RV LIFE Pro
- Joined
- Apr 10, 2016
- Posts
- 40
I have a 2019 Rockwood Mini-Lite 2512. When I purchased it (new) I installed a Southwire 35530 which is their hardwired unit. I also have the auxiliary remote display unit so I can monitor the system. The unit itself is mounted behind the power distribution box.
The surge protector is no longer working. It runs through its delay but then does not engage the contactor. The remote display shows 120V and 0A, then “Replace Surge”. Southwire says this means the surge protection circuit has failed and the unit needs to be replaced.
I am seeking opinions: Should I replace this with the same unit? Or should I look at the pedestal version instead.
Normally there would be little need to ever replace these and I’m not sure why this one failed. I do not recall any storms at the end of last season. Nor do I recall not having power as I was prepping the rig for storage. Replacing the built in unit will be a Pain but I will need to at least remove it from the circuit if I go portable. Either was I will be dealing with this failed unit.
Thought I would get some opinions from the group on this.
