Sunseeker16
- Joined
- Jun 30, 2020
- Posts
- 1,684
For someone that doesn't know, what is the purpose and/or benefit of a macerator?
I cut the old elbow off of the macerator box and glued on a 90’ 1 1/2 elbow, glued the gate valve onto the elbow, then a threaded coupling on the other side of the gate valve. The banjo fitting (male) threads onto the coupling (with plumbing tape).Halla, how is your gate valve installed? 1 1/2" threaded or did you change or add to the 90 degree fitting?
I think I can visualize that, but if you get a chance post a pic that would be greatI cut the old elbow off of the macerator box and glued on a 90’ 1 1/2 elbow, glued the gate valve onto the elbow, then a threaded coupling on the other side of the gate valve. The banjo fitting (male) threads onto the coupling (with plumbing tape).
Good to know. As a rookie this is all very new to me.No, I did this so I can always remove the hose and cap it. Less chance of breaking the hose. It takes a few seconds to hook it up, dump, unhook it and store it.
