Help! leaving tomorrow at 6am and seem to have an issue with the dump station. Just to preface this, we are brand new owners of a 2021 DX3 37BH, and first time RV'ers of any kind.
I went to the dump station today and placed the macerator hose into the dump site port. When I opened the black water valve and turned on the macerator pump switch, the macerator hose had big leaks EVERYWHERE! I turned it off and shut the valve.
I now wanted to revert to the 4" gravity feed port to complete the process. This meant removing the cap that was already holding back a bunch of waste. I used a garage bag around it to remove the cap and drain the fluid. Used the bag to drain into the dump station. I then hooked up the 4" hose and placed the other end in the dump station port. When I opened the black water valve, not only did it flow out the 4' pipe (good), but also the 1.5" macerator hose (bad).
I've gone to 3 different places around me to get a macerator hose but all need to be ordered and we don't have that time.
So the question (finally), isn't there a way to use the 4" gravity hose without it also going to the macerator hose? I don't see an independent valve anywhere.
TMI
