snapperhead
- Joined
- Mar 23, 2020
- Posts
- 10
I have an 2020 Isata-3 24RW with the Firefly 7" Multiplex control panel.
Everything works well except for the Fresh and Gray tank level readings, an issue since the RV was new.
Settings Screen: GUI Version 1.10, Logic Controller Version 1.10.
Network Diagnostic Screen: Fireware Version 1.6, Config Version 1.10.
No faults are displayed. Sensor Status are Valid.
With the RV level here's what happens:
Filling the freshwater tank, the display level increases as it should to 40% then drops to Empty and stays at Empty as the tank fills to capacity.
When draining the tank at 30 - 40% the display starts reading correctly again.
Photos Below:
1. At 30% capacity the Signal Strength is reading 13 and Red.
2. When Full the Signal Strength is reading N/A and the level shows 0%.
3. Black tank readings for comparison.
Gray tank acts the same way.
Black tank seems to operate normally.
I have a call into Firefly but have not received a return call.
Any help would be appreciated.
Photos Below:
