LOL... Tell that to the folks who won't look at a LP switch-over indicator once in a while!bluetooth on a battery is a quick easy way to see the condition of a battery
you could even watch the amp draw as you turn on stuff ... if the amps are spiking higher could give you an early warning that something could be amiss ... Just like we use to use amp gauges
it's not complicated to look at a battery once in a while
RV's that have touch screens to turn stuff on/off...... they are complicated
they got relays extra wiring etc
But there are times I wished I had a remote to turn off the light or something in the kitchen from the bed
I got a remote from amazon... used it on my boat anchor windlass... Trying to find a good use for it in the travel trailer
BTW... if I wanted to go "camping"... Would of bought a tent
RVing is NOT camping !
EDIT.... additional
For those that don't like progress and computers
stop reading the forum on the computer crap!
and toss your phone for a flip one!
Until technology gets further along,
So you 'like' his post and then find fault with it?how much further along do they need?
1/2 the weight
twice the power capacity
and charge 5 times faster
You could go lithiumION for more power density (if you dare and are crazy )
I think my fat fingers hit the wrong iconSo you 'like' his post and then find fault with it?
In my opinion, LifePo4 tech is not a perfect (or even good) fit for use in RVs, and probably will never be (especially for boondocking in winter). I'm not concerned with weight,
This is why I went to LifePo4or upgrade of charging equipment.
[So you 'like' his post and then find fault with it?
In my opinion, LifePo4 tech is not a perfect (or even good) fit for use in RVs, and probably will never be (especially for boondocking in winter). For tech to be an actual improvement, it has to make my life simpler and better. Cheaper would be a plus also. I'm not concerned with weight, my FLAs have more than enough capacity to get me through a winter night. FLAs work in any environment I find myself in w/o any heating, constant monitoring, or upgrade of charging equipment.
I will stick to my FLAs recharged by solar and generator until some battery technology comes along that actually makes my life easier in every environment I RV in.
I fully agree Mike and as technology gets further along (as I said earlier) R/Vs likely will come with LiFePo...but... that's just not yet the case. I'm sure everyone is anxious to have more available power, less weight, quicker charge times and any other advantage that comes with them but I'm just not yet willing to give up my spur of the notice, quick trip in sub freezing temperatures for a battery I can't use/charge without some special costs/considerations when what I have, works just fine.In years to come RV's will most likely come with LiFePo4 batteries that meet your requirements from the factories. Proper converters will be OEM.
Most of us today that boondock a lot are either re-vamping our existing units for more power storage for one reason or another. Weight is a consideration along with more power capacity per square or cubic foot (I now have 540 ah capacity under my jack-knife sofa in a footprint less than that of 3-100ah LiFePo4 batteries), and pretty much no maintenance except maybe for dusting. Let's not forget "Voltage Sag" which is inherent in FLA batteries which is a problem for high current devices like Microwaves as the battery bank is depleted.
Also nice to see LiFePo4 batteries fully charged from a long nights use with only a few hours of solar charging and same if generator is needed due to lack of sun.
As for heat in the winter, heated batteries are becomming more the norm except for the Low
End units.
Each user will make their own choices using their own excuses for or against one chemistry or the other. Just like the gas versus diesel, half-ton versus one-ton, etc excuses.![]()
well saidEach user will make their own choices
I don't see the contradiction. Using 5Picker as an example, I find myself disagreeing with him on some opinion posts, but he usually always presents his arguments in a thoughtful and logical manner. I literally like all of his posts for those reasons. His opinions always have merit and deserve a like, but I don't necessarily completely agree.So you 'like' his post and then find fault with it?
I don't see the contradiction. Using 5Picker as an example, I find myself disagreeing with him on some opinion posts, but he usually always presents his arguments in a thoughtful and logical manner. I literally like all of his posts for those reasons. His opinions always have merit and deserve a like, but I don't necessarily completely agree with them.
A tent?Interesting reading .....
I will stick with my lead acid batteries and learn what the heck a blue tooth even is........
Do they make RVs without all this computer crap any more. or can you take it out and trash it?? Like just on/off switches...........What ever happened to just camping?
