Model number of the Atwood might be helpful.I have a Shasta 21’ camper with Atwood water heater which works fine with the propane but does not work at all when switched to electric
Can anyone recommend some trouble shooting please
I ran into this problem when I first got my travel trailer. For me, the solution was a switch located inside the outside access bay for the water heater. It just had to be turned on. After that, the water heater worked on electric.
At the very least, it is something you can check.
Hope this helps
As a former owner of an Atwood WH, as far as I know, Atwood don't have a switch on the WH itself, only Suburban water heaters.Where exactly was that switch on the outside in the hot water tank like I said it works with the propane it just doesn’t work with electric
X2As a former owner of an Atwood WH, as far as I know, Atwood don't have a switch on the WH itself, only Suburban water heaters.
