Hello,
We are new owners of a 2019 248RBS Ultra Lite. First time camper owners as well. We've camped twice and the hot water pressure is very low flow. I'll let the water get fully presurized, turn on the hot water at a faucet, hot will come out but then eventully after several seconds will become a trickle. This is the same symptom at all faucets. Some notes:
>Cold side is normal pressure.
>After hooking up to city on the first trip, and water tank/pump usage on the second trip the flow is the same.
>When using the pump the hot tank will eventually fill up, with the pump 'burping' every few seconds, and the 'burping' timing becoming longer and eventually stoping once the hot water tank finally fills up...taking a couple hours.
>After our first trip I drained the hot water tank and the water looked clean, no sediment. I did this again after the second trip using the tank and still looked clean.
>I'm thinking the low flow is before or after the hot water tank because the same symptom of low flow happens at every faucet...no sediment at the faucets.
>No visable kinks to pipes or water damage while inspecting after I took the panel off at the pump and water heater.
>I attached a pic of the plumbing currently at the hot tank. Are the valves in their correct direction? I'm not familiar how the bypass works.
Please provide any additional troubleshooting tips that I could try for this situation.
Thank you much !
Tony
Thank you much !
Tony
