How to... replace rear turn signal lamp
heb1024
Advanced Member
Sep 15, 2014
69
2007 300ss
The rear driver's side turn signal (red cover) lamp isn't working - anyone with any ideas on how to get the cover off to replace? It's a round cover with a rubber gasket around it. :confused:
Take a small flat screwdriver and carefully pry the lens from the rubber gasket. The lens is just held in by the gasket.
When reinstalling the lens it will help if you clean the gasket and then spray some silicone around the edge of the gasket, and just work the lens back into the gasket groove.
Grumpy
So the whole lamp came out together. Can you not just replace the bulb? Or do you have to replace the whole lamp?
