Hi everyone,
My factory installed LED white awning lights went out and I purchased RGB LED light strip as a replacement from Amazon. The RGB light strip slid right in the slot where the old white LED light strip was easily.
I purchased this connection because the connection on the original wire on the RV had the same looking connection. It didn't work.
I would like to hardwire the RGB LED lights into the RV like the white LED lights. I researched and watched a lot of videos but there were not any that addressed my issue. Do I need a driver? Can I cut the wire on the RGB light strip before female end and connect directly to RV wire? Do I cut the AC adapter wire after the male end and connect to RV wire? Is there another way that I'm not aware of? Can someone please help.
Thank you all.
SPARKE RGB Led Strip Lights, 16.4ft/5m LED Tape Light, 150 Pixels RGB 5050 Waterproof Strip with 28Keys Remote and Power Supply, Chasing Effect.
DGZZI SAE Plug to DC 5.5mm x 2.1mm Male Adapter Extension Cable SAE to DC Power Automotive Connector for Solar Panel Charge 20AWG
Thank you all.
