Got a new RV and so far no real trouble with it. Couldn't get cable tv to work, removed the amplifier from the wall and found it was wired wrong. On our shake down trip from Florida to Texas I decided to check everything I could. Started at the battery disconnect, one terminal was very lose, tightened it. Opened up the electrical panel and checked every screw, several connections there were not tight at all. The grounding bar in the panel had several connections that were not tight, snug but not tight. Got into the converter and found the same thing, terminals not screwed down tight at all. At some point a single lose connection could cause some real problems, glad I checked.
