Country Girl
- Joined
- May 2, 2023
- Messages
- 5
We have a 2021 Cedar Creek 38EL with factory installed solar panel on the roof. We want to store our camper inside our garage for the winter. The garage has 4 windows at the top of the wall, which are the same height as the top of the camper.
I've read that if you disconnect your batteries you also need to disconnect the panel from the solar controller. Is this a concern when stored indoors? I realize solar panels need direct sunlight but what about what is coming through the windows? Is it enough to harm the solar controller if it isn't disconnected? I guess we could cover the panel with a blanket.
Our other option is to leave the camper plugged in all winter. I've read that is only recommended if the converter is the proper model to trickle charge the batteries and not over charge them. Does anyone with the same model camper know if we have the proper converter to leave it plugged in all winter?
Thanks for any help.
