Silver45
- Joined
- Aug 26, 2020
- Posts
- 4
Having some difficulties figuring out my newly purchased 5th wheel. I picked up a 2017 Sierra 354 RET. I got the rig home and realized while going through it the Inverter was not on. Next day went and purchased 2 new batteries 12v ACM.
I hooked back up and still nothing. Fuse box fuses good, breakers on, etc. I pulled out the inverter and opened it up because it did not have an external fuse but did have a circuit overload button on back which was fine. Inside the inverter had 4 40a fuses soldered to the board, all blown. My thought is it may have happened while transporting the coach home due to the way the guy had the batteries sitting in the batt box. Positive post right next to metal and were not secure. SO i replaced them and reinstalled. Connected to batteries and it fired up and began to run, the fans and lights were on on the device and fridge worked in the trailer. Next day I came out and power on inverter out again but this time when I disconnected battery the 100a circuit breaker between the battery and the inverter reset making a click. Re-hooked up the inverter and worked for a few mins then breaker popped. Now here is where it gets confusing. if I hook up shore power inverter runs.
Question is is there something wrong or am I screwing up somewhere.
No power to fridge without shore power.
The inverter is a Arterra WF5110hp 1000 watt and I believe is factory for the trailer. It has a separate converter if that matters. Any help appreciated.
